OMM Consumer Config encryption query
Thanks if you can guide for below.
When using the following connection method from the OmmConsumerConfig interface, is the traffic encrypted?
OmmConsumerConfig config = EmaFactory.createOmmConsumerConfig();
config = EmaFactory.createOmmConsumer(config.host(“ip:port”).username(“username”));
  • If not, can you please indicate which method from the OmmConsumerConfig interface should be used for SSL encryption?
Thank you in advance,
Serhat
ema-apiommconsumer
Hi @serhat.gulsen1
Please see this article on using an encrypted connection between a consumer and an ADS.
Configuring Encrypted Connections on ADS | Refinitiv Developers
As mentioned in the article, ADS 3.4 onwards is required with Encryption enabled on the ADS.
Some older ADS versions can also support an Encrypted connection using an additional encryption device - an SSL accelerator. This is also mentioned with additional links in the above article.
