Can we set the absolute path/relative path/base dir for the Ema log file EmaLog_pid.log?
Hi @Frederic
This can be specified using normal EMA Configuration parameters i.e. EMAConfig.xml or programmatic config, using the Logger Group entry Parameters - please refer to the EMAConfigGuide PDF file for full details.
For example, if using a config file - in your Consumer config, you specify a Logger entry name
<ConsumerGroup> <ConsumerList> <Consumer> <Name value="Consumer_1"/> <Channel value="Channel_1"/> <Logger value="Logger_2"/> <Dictionary value="Dictionary_1"/> <XmlTraceToStdout value="0"/> </Consumer> </ConsumerList> </ConsumerGroup>
Then you configure the Logger_2 config as required e.g.
<LoggerGroup> <LoggerList> <Logger> <Name value="Logger_2"/> <LoggerType value="LoggerType::File"/> <FileName value="c:/temp/myEmaLog.log"/> <LoggerSeverity value="LoggerSeverity::Success"/> </Logger> </LoggerList> </LoggerGroup>
