i'm trying to build jison to retrive data from datastream, with list of fields.
didnt find any information on the documantation via getdata or getdatabundle.
does anyone have an example for jison?
thanks,
Y.D
thanks,
Y.D
You can check the REST API documentation here.
The JSON request message for above get_data request will be:
POST https://product.datastream.com/DSWSClient/V1/DSService.svc/rest/GetData { "DataRequest": { "Instrument": { "Properties": null, "Value": "<VOWG_p.DE>" }, "DataTypes": [{ "Properties": null, "Value": "VO" }, { "Properties": null, "Value": "P" } ], "Date": { "End": "", "Frequency": "", "Kind": 1, "Start": "2017-01-01" }, "Tag": null }, "Properties": { "Key": "Source", "Value": null }, "TokenValue": "**** TOKEN VALUE *****" }
Hi @YD,
If you are using Python, I would recommend to use the DSWS library for requests, and invoke the API like:
df = ds.get_data(tickers='<VOWG_p.DE>', fields=['VO','P'], start='2017-01-01', kind=1)
which returns a dataframe with all the values.
To get the list of all the fields, please use the Datastream Navigator.
Hi Gurpreet,
Thanks for your fast reply.
Do you have an example using json? i want to check it via postman.
Thanks,
Y.D
this is my issue,
i dont see in this retrieval how can i get fields like
NAME
ASSET_TYPE
OPERATING PROFIT MARGIN
PCHV#(X)RI YTD)
X(WC03255)/X(WC02999)
REC BUY %
ACCRUED INTEREST
i understood there are initial names to these fields so i'm moving forward on this but i have a question regarding expression api, i'm trying to get respose from this request(got example from the test simulator) but i'm keep getting error , so what is the issue here?
"DataRequest": {
"DataTypes": [
"Properties": null,
"Value": "MAX#(X,52W)"
"Date": {
"End": "",
"Frequency": "",
"Kind": 0,
"Start": "2021-11-01"
"Instrument": {
"Properties": [
"Key": "IsExpression",
"Value": True
"Value": "<mgx.ax>"
"Tag": null
"Properties": null,
"TokenValue":"some token"
