Token retrieve error
I couldn’t retrieve a token because I got an error on User Name. Why doesn’t my ID work?
datastream-apidsws-apitoken
1.1k 3 3 3
Hello @Catherine Wong,
For an ID to work below criteria should be met:
  • ID needs to be entered in the correct Datastream format – in capitals starting with a Z (for example ZABC123).
  • Access to DSWS requires permission to be added to the ID. If you don't have it you would need to contact your account team.
Thank you. Now I received a token, but it seems to be way too long.
How long is the token supposed to be ?
1.1k 3 3 3
@Catherine Wong
The Token is 256 characters long.
