Hi, I am getting the titled error, which I have seen mentioned by other people but the general response seems to be check with your administrator. Having contacted Refinitiv I received the following response, "I have reached out to the relevant team to help us check on your Datastream DSWS credentials. It is also confirmed that you are entitled to DSWSAPID." so I would assume I do have the right access levels. Could you please advise in how to resolve this issue?
