No acknowledge status message for single item request, but works for batch request
For batch request, there will be an acknowledge status message:
StatusMsg
streamId="5"
domain="MarketPrice Domain"
state="Closed / Ok / None / 'Batch request acknowledged.'"
StatusMsgEnd
However, for the normal single item request, there will be no such acknowledge status message. Is that the case? and the reason? or some configuration controls this behavior, either on server side or client side.
batchstatus
11.5k 16 7 10
Hello @Frederic
It is expected behavior. With a Batch subscription, the Real-Time server closes the batch items request streams, and then sends each item data back to the API via individual streams, so the API needs to notify the application about that "request stream close" event.
With a single item subscription, the server sends data back to the API via the same item request stream, so there is no notification regarding the stream being closed.
