Im trying to process error handling for channel disconnections and errors. I can see that the Eleketron already logs an error containing the info that I want but the StatusMsg that I receive from the OmmConsumerClient do not have this info.
Below is what logs I see from the Elektron logs. I want to be able to get the Text containing Channel_1 and Channel_2 as well as the connection refused..
WARN 2020-02-11 06:08:37.199-0600 OmmConsumerImpl [pool-3-thread-1]- loggerMsg ClientName: ChannelCallbackClient Severity: Warning Text: Received ChannelDownReconnecting event on channel Channel_2 RsslReactor @5aaf0534 RsslChannel @3c5be0d Error Id 0 Internal sysError 0 Error Location Reactor.processWorkerEvent Error text Error initializing channel: errorId=-1 text=Connection refused loggerMsgEnd ERROR 2020-02-11 06:08:42.206-0600 OmmConsumerImpl [pool-3-thread-1]- loggerMsg ClientName: ChannelCallbackClient Severity: Error Text: Received ChannelDown event on channel Channel_1 Instance Name ReutersConsumer_1 RsslReactor @5aaf0534 RsslChannel @5468f011 Error Id 0 Internal sysError 0 Error Location Reactor.processWorkerEvent Error text Error initializing channel: errorId=-1 text=Connection refused loggerMsgEnd
The StatusMsg that I received only tells that the channel has closed and does not tell which of the multiple channels is down.
WARN 2020-02-11 06:08:42.206-0600 LoginOMMConsumerClient [pool-3-thread-1]- Login state is not OK. State=Closed / Suspect / None / 'channel closed', Msg=StatusMsg streamId="1" domain="Login Domain" state="Closed / Suspect / None / 'channel closed'" name="DEV" nameType="1" StatusMsgEnd
