I am using Reginitiv's sample perl scripts to retrieve RICs. It's working fine when retrieving the default IDN_RDF feed from one ADS server, but it is not clear from the perl samples how to:
1. Specify an alternative ADS server during initial configuration, so that if the first ADS fails, the data will be retrieved from the alternative ADS server.
2. Specify RICs from other sources of data, like DDS or KRS (Kondor+).
Thanks,
Ofer
