Error when setting up key
As i was trying to set up key for eikon, this error shows up, could you help me solve it? Thank you so much!
eikoneikon-data-apiapp-key
@An.T.Nguyen
I assumed that you are using the httpx version 0.20.0.
I got the same error when using the Eikon Data API with the httpx 0.20.0.
Please downgrade the version of the httpx to 0.19.0
 pip install httpx==0.19.0
You can verify the httpx version by using the following command.
C:\>pip show httpx
Version: 0.19.0
Summary: The next generation HTTP client.
Home-page: https://github.com/encode/httpx
Author: Tom Christie
Author-email: tom@tomchristie.com
License: BSD
Requires: rfc3986, charset-normalizer, httpcore, sniffio, certifi
Required-by: refinitiv-dataplatform, eikon
