Handshake Error.
Hi, I am getting the following error when I run ek.set_app_key().
I did not have this issue when running ek.set_app_id().
It does not seem to affect performance, but wondering what I can do to resolve. Thank you.
Error on handshake port 36036 : HTTPConnectionPool(host='localhost', port=36036): Read timed out. (read timeout=2.0)
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonapp-keyhandshakeinitialization
@jr123 could you execute this and post the output?
tr.get_port_number()
Also, if you go to Help > Event logs, go to Local Logs, select Today and SxS, and hit Open
Scroll to top and post the screenshot of this as well please
Hi @Zhenya Kovalyov,
Thank you for the response.
ek.get_port_number() returns '36036'
How can I access the event log on a mac?
Regards, J
@jr123 what's you eikon api proxy version? when you are running it, which url does it show in the DATACENTER field?
version 1.0.73
data center field: AMERS1
data center URL: http://localhost:36036/api/v1/data
4.6k 26 7 22
@jr123I think you need to update the API proxy version. I will send you an email with the details.
4.6k 26 7 22
@jr123 I think you need to update the API proxy version. I will send you an email with the details.
