App Key Generator Error
Unable to generate App Key with Error: "Server error: Application 'THEWOODBRIDGECOMPANY.AIKONAPI' aready exisits"
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonapp-key
This means someone from the same company that you work for already registered an application with the same name you tried to use. Pick a different name for your application.
Yes, created with a different name. Thank you!
