DSS REST API - Premium Pricing (Cycles) - by Data Availability via On Demand (/ExtractWithNotes and/or /ExtractRaw)
I just wanted to check, but I believe 'Data Availability' hasn't been implemented via DSS API 'On Demand'? I can't see any sign of it in the API reference tree so initailly I am assuming not available.
More specifically the use case relates to being able to submit an 'On Demand' request for Premium Pricing (Asia - 1500 JST) and have the request only then returning the data once the data for the 1500 time (assuming request has been sent prior to that day's run) is ready.
It look as though this is only possible through the Scheduled method?
Is it possible to look at implementing?
Best regards,
Gareth
23k 22 9 14
Hello @gteage ,
I believe you are looking at embargo procedure in DSS, and how to handle it in on-demand code?
You can find out about embargo procedures in DSS in Refinitiv DataScope Select GUI User Guide -> "About Embargoed Extractions".
If you are looking to handle embargoes in code, please see Tutorial: On Demand intraday extraction, embargo for an approach explanation and how to handle. The same approach as used for embargoed Intraday applies to embargoed Premium EOD Pricing.
Hope this helps, otherwise, please let us know more of your question?
@zoya faberov Thanks Zoya!
