Hello @dilip.kha ,
Have you downloaded examples RTH Python Code Samples ?
Are you looking at the example OnDemand_IntradayBars.py?
Do you see in code:
#Step 4: get the extraction results, using the received jobId. #Decompress the data and display it on screen. #Skip this step if you asked for a large data set, and go directly to step 5 !
Prior to this in
#Step 2: send an on demand extraction request using the received token
Is where I was suggesting to replace TickHistoryIntradaySummariesExtractionRequest with your required request.
I have adapted this sample for T&S use before, perhaps you will find this change useful, please find it attached.
Hello @dilip.kha ,
After receiving status = 200, you can pull the result from:
https://selectapi.datascope.refinitiv.com/RestApi/v1/Extractions/RawExtractionResults({jobID})/$value
You may find useful REST API Tutorial 4: On Demand tick data extraction where on demand requesting of TickHistoryTimeAndSales is discussed in detail.
Next, if you are looking to implement in python, one approach could be to download a working python on demand example RTH Python Code Samples and swap JSON request in the example with your required JSON request, while reusing the rest of the code.
Hi @zoya faberov ,
Thank you so much for answering my question. However, I did see the doc you mentioned, but I could not find any useful code to use in Python.
All I want is, after getting status_code=200, I want to pull the data using below code/EndPoint. I'm getting result as 200 when I try to print in the last line.
result: <Response [200]>
Please see if you can help me on that. Thank you.
