TRTH ExtractRawResult returns Error 404
I'm creating a python sample around TRTH starting from the tutorial and I'm getting this 404 error in the last step of the process. Would anyone have a working python sample ?
  • Getting the token works fine
import requests
import json
requestUrl = "https://hosted.datascopeapi.reuters.com/RestApi/v1/Authentication/RequestToken"
requestHeaders={
    "Prefer":"respond-async",
    "Content-Type":"application/json"
requestBody={
    "Credentials": {
    "Username": "XXXXX",
    "Password": "*****"
r = requests.post(requestUrl, json=requestBody,headers=requestHeaders)
jsonResponse = json.loads(r.text.encode('ascii', 'ignore'))
token = jsonResponse["value"]
print token
returns succesfully the token
  • then I can successfuly post a request
Url='https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/ExtractRaw'
requestUrl=Url
requestHeaders={
    "Content-Type":"application/json",
    "Authorization": "token " + token
requestBody={
  "ExtractionRequest": {
    "@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.TickHistoryIntradaySummariesExtractionRequest",
    "ContentFieldNames": [
      "Close Ask",
      "Close Bid",
      "High",
      "High Ask",
      "High Bid",
      "Last",
      "Low",
      "Low Ask",
      "Low Bid",
      "No. Asks",
      "No. Bids",
      "No. Trades",
      "Open",
      "Open Ask",
      "Open Bid",
      "Volume"
    "IdentifierList": {
      "InstrumentIdentifiers": [{
        "Identifier": "CARR.PA",
        "IdentifierType": "Ric"
      "UseUserPreferencesForValidationOptions":"false"
    "Condition": {
      "MessageTimeStampIn": "GmtUtc",
      "ReportDateRangeType": "Range",
      "QueryStartDate": "2016-09-29T00:00:00.000Z",
      "QueryEndDate": "2016-09-30T00:00:00.000Z",
      "SummaryInterval": "OneHour",
      "TimebarPersistence":"true",
      "DisplaySourceRIC":"true"
print r
print r.headers
print r.headers["location"]
and get as expected
<Response [202]>
{'Status': 'InProgress', 'Content-Length': '0', 'X-Request-Execution-Correlation-Id': 'c9034ca7-94d4-4c5a-a4ee-75e499b88457', 'X-App-Id': 'Custom.RestApi', 'Set-Cookie': 'DSSAPI-COOKIE=R3479498792; path=/', 'Expires': '-1', 'Server': 'Microsoft-IIS/7.5', 'X-App-Version': '11.0.492.64', 'Location': "https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/ExtractRawResult(ExtractionId='0x05b94284924b3016')", 'Pragma': 'no-cache', 'Cache-Control': 'no-cache', 'Date': 'Fri, 19 May 2017 09:42:01 GMT', 'Progress': ''}
  • I can then pull the status
requestUrl = r.headers["location"]
print requestUrl
requestHeaders={
    "Authorization":"token " + token
r2 = requests.get(requestUrl,headers=requestHeaders)
print r2
print r2.headers
until I get
<Response [200]>
  • However, when I try to retrieve the content using
requestUrl = r.headers["location"] + "/$value"
requestHeaders={
    "Accept-Encoding":"gzip, deflate",
r3 = requests.get(requestUrl,headers=requestHeaders)
print r3
I get
<Response [400]>
would anyone have a working python sample ?
Many thanks
pythontick-history-rest-api
13.7k 26 8 12
@samuel.schwalm
400 is a bad request, 404 indicates that the resource specified by the request URL does not exist (see status codes here).
The issue is with the URL when you try to retrieve the content. It is not the location URL. Instead, you must use this URL:
https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/RawExtractionResults('0x05b94284924b3016')/$value
This URL contains the JobId (0x05b94284924b3016) which was returned in the body of the previous 200 response.
You can find the details of the On Demand request workflow in this tutorial, and this particular step is described here.
Many thanks @Christiaan Meihsl
Indeed with the right url it works better!
requestUrl = "https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/RawExtractionResults" + "('" + jobId + "')" + "/$value"
requestHeaders={
    "Content-Type":"text/plain",
    "Accept-Encoding":"gzip",
extract = r3.text
print r3
print extract
or with a panda dataframe
rom StringIO import StringIO
import pandas as pd
timeSeries = pd.read_csv(StringIO(r3.text))
timeSeries
Many thanks
Samuel
Great, good to know :)
