A few hours ago, I saw the error message like below.
Is There Any URL or Page, Docs can see the description of error message list?
2021:10:13 13:40:07.903 WARN --- [pool-13-thread-1] c.t.ema.access.OmmConsumerImpl : loggerMsg ClientName: ChannelCallbackClient Severity: Warning Text: Received ChannelDownReconnecting event on channel DATA_CHANNEL_1 RsslReactor @276f412c RsslChannel @53b007ab Error Id -3 Internal sysError 0 Error Location Watchlist.encodeIntoBufferAndQueue Error text socket channel is not in the active state for read loggerMsgEnd 2021:10:13 13:40:07.903 WARN --- [pool-13-thread-1] c.t.ema.access.OmmConsumerImpl : loggerMsg ClientName: LoginCallbackClient Severity: Warning Text: RDMLogin stream state was changed to suspect with status message username <not set> usernameType <not set> State: Open/Suspect/None - text: "" loggerMsgEnd 2021:10:13 13:40:08.940 INFO --- [pool-13-thread-1] c.t.ema.access.OmmConsumerImpl : loggerMsg ClientName: ChannelCallbackClient Severity: Info Text: Received ChannelUp event on channel DATA_CHANNEL_1 Instance Name CONSUMER_1_1 Component Version ads3.3.3.L1.linux.tis.rrg 64-bit loggerMsgEnd
