Govermental Ownership (%) for a given list of companies
In a context of my financial thesis I need help to build my database.
Is there a way to display the governmental ownership in percentage for a given company (Using PermID) Thank you in advance
Tom
world-checkworld-check-one
@TomLeo
I assume that you are using the get_data method in Eikon Data API in order to retrieve data.
This forum is more for programming-type queries, rather than content queries. I would recommend you to contact the Eikon support team directly via MyRefinitiv. You can ask for the =TR formula in the Eikon Excel which can be used to retrieve the governmental Ownership (%) for a given list of companies.
If the formula is available, we can apply it to the get_data method in Eikon Data API. That way a content specialist can work closely with you to find a way to get the required data.
However, if you are not using Eikon Data API, please let us know Refinitiv Products that you are using.
