what will be the body request in on going screening enable API
We are trying to consume SEQ-case-ogs-enable: Enable ongoing screening for a case and we have a question for API body. The collection gives body like this
{ "providerTypes": [ "WATCHLIST" ]}
If we didnt subscribe to watchlist what should we pass as body for this API to enable OGS?
world-checkworld-check-onescreening-api
1.1k 3 1 2
@tarini.prasaddash
The provideType "WATCHLIST" here donates that your OGS is enabled against the World-Check database, so any changes/updates to the matches will flag the OGS update for you and the other supported value in the providerType here "MEDIA_CHECK" as mentioned in the documentation.
OngoingScreeningProviderType
Ongoing screening supported provider types
Type : enum (WATCHLIST, MEDIA_CHECK)
You can download the latest documentation from the link below:
https://developers.refinitiv.com/en/api-catalog/customer-and-third-party-screening/world-check-one-api/downloads
Please refer to the technical documentation and test it with the payload as it is, Hope this is helpful, and let us know if you have any other concerns.
Thank you Mehran, Sorry if it is a silly question but I amnew here. Can we use v1.6x instead of 2.4 or it is no more supported?
Our application is still using v1.6 APIs so not sure which OGS API version to choose
1.1k 3 1 2
@tarini.prasaddash
It is still supported and you can use it, but I would recommend you test out the latest version so that you can explore the potential to keep your implementation up to date and utilize any additional functionalities that you may want to add as enhancements in the future.
