Code for tutorials not up-todate?
I'm following the tutorial here https://developers.refinitiv.com/en/api-catalog/refinitiv-real-time-opnsrc/rt-sdk-cc/tutorials#ema-consumer-creating-a-barebones-ema-consumer-application
However, that page shows code like
class AppClient : public refinitiv::ema::access::OmmConsumerClient
which does not match the code from the download link https://developers.refinitiv.com/content/dam/devportal/api-families/elektron/elektron-sdk-c/tutorials/ema-consumer/ema_tutorials.zip
where I can see code like
class AppClient : public thomsonreuters::ema::access::OmmConsumerClient
which does *not* compile using SDK 2.0.2
Where is the up-to-date tutorial code for SDK version 2.0.2 please?
elektronelektron-sdkrrtema-apirefinitiv-real-time
1.7k 2 4 7
9.7k 49 38 60
Hi @dmenendez
Thank you for raising this. We are in the process of updating the learning material and will correct that ASAP. Part of the rebranding work recently done by the RTSDK team was to rebrand the namespace. You should be able to move forward immediately by changing the namespace within the tutorial code you downloaded.
