Suppress error text while requesting data in Eikon API
I am testing the validity of a RIC trying both "try.. Except" (as suggested also here) and "With Suppress" functions to continue the loop and get correct RICs into a list. Although, the code works and adds correct RICs to the list I still see the message telling the RIC is incorrect. Please see attached the screenshot and putting one of them here below as well: try_except.png
RICs = ['NDXl1721A8290.U^L21', 'NDXl1721A8275.U^L21', 'NDXd1621A6275.U^D21','NDXd1621A6300.U^D21']
valid_rics = []
for RIC in RICs:
with suppress(ek.EikonError):
a = ek.get_timeseries(RIC, fields = ['CLOSE'], start_date = '2021-01-01', end_date ='2021-04-18',interval='daily' )
valid_rics.append(RIC)
valid_rics
Is there a way to hide that? Please also note that error text appeared while using the loop and it is ignored when the code is run without a loop for a single RIC.
I would appreciate if you help to find a way of suppressing error message while using the loop.
rics
4.3k 2 4 5
Hi @haykaz.aramyan,
Messages arn't displayed because of an EikonError exception, it's logged as warnings.
That's why "with suppress(ek.EikonError)" has no effect.
There is mainly 3 options to stop warning at screen:
  1. Disable all warnings (from any lib):
    import warnings
    warnings.filterwarnings("ignore")
  2. Disable displayed warnings from eikon:
    import logging
    import eikon as ek
    ek.set_app_key("xxxxxxxxxx")
    logger = logging.getLogger("pyeikon")
    logger.propagate = False
  3. Reduce log level to ERROR (warnings will be ignored):
    import logging
    import eikon as ek
    ek.set_log_level(logging.ERROR)
Hi @pierre.faurel ,
Thank you for your reply, that was very helpful, 2nd solution solved my problem.
Best regards,
Haykaz
