Eikon API time series request: single RIC (not in list) with lower case results in errors?
It looks like 'get_timeserie's does not give correct output when using a single RIC with a lower case only when it is not in a list.
The following command:
eikon.get_timeseries('BRKb.N')
Results in:
('BRKB.N', ': ', 'Error: TSIUnknownInstrument, ErrorCode: TA-TSIUnknownInstrument, Fault: TSIError, Description: Invalid RIC', '\n')
While the following commands work just fine:
eikon.get_timeseries(['BRKb.N'])
eikon.get_timeseries(['BRKb.N', 'IBM'])
Could you please look into this? Thanks!
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonricstime-series
Please refer to this question.
This issue will be fixed in a next version (> 0.1.10).
4.3k 2 4 5
Thanks, this issue was identified and will be fixed in a next version.
