Datastream Data For BackTrader
Hello, is there someone that coud help to feed Datastream data into Backtrader using the following example ?
from datetime import datetime
import backtrader as bt
# Create a subclass of Strategy to define the indicators and logic
class SmaCross(bt.Strategy):
    # list of parameters which are configurable for the strategy
    params = dict(
        pfast=10,  # period for the fast moving average
        pslow=30   # period for the slow moving average
    def __init__(self):
        sma1 = bt.ind.SMA(period=self.p.pfast)  # fast moving average
        sma2 = bt.ind.SMA(period=self.p.pslow)  # slow moving average
        self.crossover = bt.ind.CrossOver(sma1, sma2)  # crossover signal
    def next(self):
        if not self.position:  # not in the market
            if self.crossover > 0:  # if fast crosses slow to the upside
                self.buy()  # enter long
        elif self.crossover < 0:  # in the market & cross to the downside
            self.close()  # close long position
# create a "Cerebro" engine instance
cerebro = bt.Cerebro()
# Create a data feed
data = ds.get_data(tickers='@MSFT', fields=['PO','PH','PL','P','RI','VO'], start='-5Y', end='0D', freq='D')
cerebro.adddata(data)  # Add the data feed
cerebro.addstrategy(SmaCross)  # Add the trading strategy
cerebro.run()  # run it all
cerebro.plot()  # and plot it with a single command
The cerebro.adddata(data) # Add the data feed gives an error.
Any help would be highly appreciated !
datastream-apidsws-apidatastreambacktesting
@anilo
You need to use the bt.feeds.PandasData method instead.
The code looks like this.
datads = ds.get_data(tickers='@MSFT', fields=['PO','PH','PL','P','VO'], start='-5Y', end='0D', freq='D')
datads.columns = datads.columns.droplevel()
datads.index = pd.to_datetime(datads.index, format='%Y-%m-%d')
datads = datads.rename(columns={"PO": "Open",
                       "PH":"High",
                       "PL":"Low",
                       "P":"Close",
                       "VO": "Volume"})
data = bt.feeds.PandasData(dataname=datads.dropna())
Great!
Many thanks.
However there is now another error related to the plot, since I have the
Javascript Error: IPython is not defined
https://newbedev.com/javascript-error-ipython-is-not-defined-in-jupyterlab
Or maybe is due to the fact that Pandas needs to have a specific column format ? See https://www.backtrader.com/docu/pandas-datafeed/pandas-datafeed/
@anilo
I have followed the steps mentioned in the stackoverflow.
Then, I ran the following code.
%matplotlib widget
cerebro.plot(iplot=False)
The plot is shown properly.
Cool! Now it works!
Many thanks!
