How can I return date with corresponding value when calling GetData with DSTimeSeriesDate using datastream .net api
Here is an example
var datatype = "REBE#(X/FTSE100)-100";
var request = new DSDataRequest()
Instrument = new DSInstrument(identifier),
DataTypes = new DSDataTypes(datatype),
Date = new DSTimeSeriesDate(DSDateType.Literal("-2Y"), DSDateType.Literal(""), DSDateFrequency.Daily),
var response = DSClient.DataService.GetData(request);
double[] values = response[datatype][identifier].GetValue<double[]>();
How can I return collection of objects that gives date and its corresponding value
apidatastream-apidsws-api.netdatastream
@vishal.kak
Dates can be accessed via response.Dates.
            double[] values = response[datatype]["U:IBM"].GetValue<double[]>();
            for (int i = 0;i < values.Length; i++){
                Console.WriteLine("{0} \t {1}", response.Dates[i], values[i]);
@vishal.kak
If you were using Datastream Web Service WSDL, as described in DSWS Tutorial - Microsoft Visual Studio, the array of dates is provided by the Dates property of DSDataResponse class. However, you mentioned on this thread, that you're using ThomsonReuters.DswsApi.NET4.5.dll, which I'm not familiar with. I'm afraid before I can give you any advise, I need to understand what ThomsonReuters.DswsApi.NET4.5.dll is. Would you mind sharing where you got it from? I couldn't find any references to it internally or externally.
