Hi Team
We are observing some exception in websocket client application (Error "An exception has occurred while receiving. (1006 Abnormal)")
In order to recover from this issue , we need to bounce the application.
Application logs
2021-09-14 10:24:21,722 [121] INFO : MarketDataLog - WebSocket (ny1-cld-ws-ct.am.hedani.net) was closed: An exception has occurred while receiving. (1006 Abnormal)
2021-09-14 10:24:21,722 [121] INFO : MarketDataLog - MarketDataConnectionStatusChange ConnectionDown: Connection down
2021-09-14 10:24:21,723 [335] INFO : MarketDataLog - Connecting to WebSocket ws://ny1-cld-ws-ct.am.hedani.net:15000/WebSocket
2021-09-14 10:24:21,729 [335] INFO : MarketDataLog - Connected to ny1-cld-ws-ct.am.hedani.net
2021-09-14 10:24:21,729 [335] INFO : MarketDataLog - MarketDataConnectionStatusChange ConnectionUp: Connection up. Host=ny1-cld-ws-ct.am.hedani.net Position=169.254.1.222 User=559_mavenserver_0 Appid=559
2021-09-14 10:24:21,729 [335] INFO : MarketDataLog - Attempting login for 559_mavenserver_0 [appid = 559]
2021-09-14 10:24:21,735 [121] INFO : MarketDataLog - Reconnected to new WebSocket so redoing all subscriptions
2021-09-14 10:24:34,217 [181] INFO : MarketDataLog - MarketDataAdapter.Unsubscribe PI_L1_INT|CPSL3|FieldList|0
2021-09-14 10:24:34,334 [211] INFO : MarketDataLog - WebSocket (ny1-cld-ws-ct.am.hedani.net) was closed: An exception has occurred while receiving. (1006 Abnormal)
2021-09-14 10:24:34,335 [211] INFO : MarketDataLog - MarketDataConnectionStatusChange ConnectionDown: Connection down
2021-09-14 10:24:34,335 [24] INFO : Gcl.DataSources.Triarch.TriarchDataSource - Market data connection is down
2021-09-14 10:24:34,335 [152] INFO : MarketDataLog - Connecting to WebSocket ws://ny1-cld-ws-ct.am.hedani.net:15000/WebSocket
2021-09-14 10:24:34,342 [295] INFO : MarketDataLog - Unsubscribing 37139 PI_L1_INT|SITM.O|FieldList|0
2021-09-14 10:24:34,342 [295] ERROR: MarketDataLog - Received Error: An error has occurred in sending data.
2021-09-14 10:24:34,342 [121] INFO : MarketDataLog - WebSocket (ny1-cld-ws-ct.am.hedani.net) was closed: An exception has occurred while receiving. (1006 Abnormal)
2021-09-14 10:24:34,342 [121] INFO : MarketDataLog - MarketDataConnectionStatusChange ConnectionDown: Connection down
2021-09-14 10:24:34,342 [121] INFO : MarketDataLog - Connecting to WebSocket ws://ny2-cld-ws-ct.am.hedani.net:15000/WebSocket
2021-09-14 10:24:34,338 [152] INFO : MarketDataLog - Connected to ny1-cld-ws-ct.am.hedani.net
2021-09-14 10:24:34,342 [152] INFO : MarketDataLog - MarketDataConnectionStatusChange ConnectionUp: Connection up. Host=ny1-cld-ws-ct.am.hedani.net Position=169.254.1.222 User=559_mavenserver_0 Appid=559
2021-09-14 10:24:34,342 [152] INFO : MarketDataLog - Attempting login for 559_mavenserver_0 [appid = 559]
2021-09-14 10:24:34,342 [152] ERROR: MarketDataLog - Received Error: An error has occurred in sending data.
2021-09-14 10:24:34,353 [24] INFO : Gcl.DataSources.Triarch.TriarchDataSource - Sending stale message for PI_L1_INT CLLDY
2021-09-14 10:24:34,353 [24] INFO : Gcl.DataSources.Triarch.TriarchDataSource - Sending stale message for PI_L1_INT SAWAD/F
2021-09-14 10:24:34,353 [24] INFO : Gcl.DataSources.Triarch.TriarchDataSource - Sending stale message for PI_L1_INT TGNA
2021-09-14 10:24:34,353 [181] INFO : MarketDataLog - WebSocket (ny2-cld-ws-ct.am.hedani.net) was closed: An exception has occurred while receiving. (1006 Abnormal)
2021-09-14 10:24:34,353 [181] INFO : MarketDataLog - MarketDataConnectionStatusChange ConnectionDown: Connection down
2021-09-14 10:24:34,353 [181] ERROR: MarketDataLog - Unable to connect. No more hosts to try
ADS server logs for the same client for that Day
<uslp9019593.1.ads: Warning: Tue Sep 14 15:28:31.424217 2021> Output threshold OK for "559_mavenserver_0" at position "169.254.1.222" on host "" using application "559" on channel 54. Resuming normal operation.<END>
<uslp9019593.1.ads: Warning: Tue Sep 14 15:28:30.987627 2021> Output threshold breached for "559_mavenserver_0" at position "169.254.1.222" on host "" using application "559" on channel 54.<END>
<uslp9019594.1.ads: Warning: Tue Sep 14 10:24:28.680732 2021> Output threshold breached for "559_mavenserver_0" at position "169.254.1.222" on host "" using application "559" on channel 53.<END>
<uslp9019593.1.ads: Warning: Tue Sep 14 10:06:31.477451 2021> Output threshold breached for "559_mavenserver_0" at position "169.254.1.222" on host "" using application "559" on channel 49.<END>
<uslp9019593.1.ads: Warning: Tue Sep 14 09:46:15.228024 2021> Output threshold OK for "559_mavenserver_0" at position "169.254.1.222" on host "" using application "559" on channel 49. Resuming normal operation.<END>
<uslp9019593.1.ads: Warning: Tue Sep 14 09:46:15.124027 2021> Output threshold breached for "559_mavenserver_0" at position "169.254.1.222" on host "" using application "559" on channel 49.<END>
Our observation
It look like when the first time this error happened @10:24:21 , there were no buffer overflow at ADS
Later on application try to resubscribe all the instrument.
Then I can see buffer overflow message at ADS side @10:24:28
Wondering what could be reason for this error at first time ?
