Refinitiv Data Platform authentication HTTP code: 400 Bad Request
Hi May I know if the examples provided in Download is the same as those in Gitlab. Reason asking is that in the QuickStart has mentioned that "The Refinitiv Real-Time - Optimized Quick Start example application is available for download at Refinitiv Developer Community: WebSocket API download page or Refinitiv/websocket-api: GitHub page. "
However I found the files have different names
- In Download page below it is "market_price_edpgw_service_discovery.py"
- In Gitlab page it is "market_price_rdpgw_service_discovery.py "
And when I tried to run the example as guided in the Quick Start
python market_price_rdpgw_service_discovery.py --user xxxx --password xxx --clientid xxx
I got the following errors
Can you please advise what may have been wrong? Thanks
pythonwebsocketsrrtorefinitiv-realtime-optimised
Hi @JoJo
Apologies - the rdp_aws_examples.zip file should have been deleted - which I have now done (the RDP examples are contained within the main Websocket API Sample Applications zip file in an RDP subfolder and should be identical to the GitHub versions)
Can you confirm you are providing the correct parameters:
  • -user = is the MachineID you would have received in a Welcome email e.g. GE-A-01234567-0-1234
  • -password = the long password set using the above Welcome email link
  • -clientID = the AppKey generated using App Key Generator (and clicking the EDP API checkbox)
Details of the key generator and other information can be found in the Websocket API - RRTO QuickStart
If you are using the correct parameters, please provide some more of the output - before and after the error.
Please do NOT include any username, password or clientID in the shared output.
Hi @JoJo
I have just checked and I don't see any MachineID allocated to an account linked to your email address. If this is the case, please reach out to your Refinitiv Account contact and discuss the possibility of a trial.
