EMA Java Configuration
Dear wasin.waeosri , umer.nalla
As suggestted in the previous thread discussion we tried Downloading the RTSDK Java package for EMA Java API library files.
When we are requesting access to Refinitive Real Time SDK, the message appears as - 'This software will be installed at this address.'
Kindly confirm if any additional infrastructure has to be installed to run EMA for capturing rates.
elektronrefinitiv-realtimeelektron-sdkrrtema-api
Hi @kishore.karanam
If you are using Real-time Optimised for the data, you do not require any additional infrastructure.
The RT-SDK can connect to the same infrastructure as the Websocket API that you have been using. You can refer to the Quick Start guide for more details on getting started and connected with RT-SDK
NOTE: the Java keystore file mentioned in the above QuickStart is now optional (it now uses the default JVM one) - so unless you want to use your own, you can ignore the Keystore file stuff.
