Message received contains unexpected values for some fields.
some messages received from Refinitiv Real Time Optimized Websocket API have unexpected values for some fields.
Example:
"DSPLY_NMLL": "\u001b[0` \u001b[31b",
"CTBTR_1LL": "\u001b[0`<CALCS_EXPLAINED>\u001b[17` \u001b[4b"
What is this means and how can I decode this?
Thanks,
websocketsrrtorefinitiv-realtime-optimisedmessages
@thomas.abraham
It is a partial field update, as mentioned in this How to retrieve page-based data using Refinitiv Tick History REST API article.
For exmple: "\u001b[0` \u001b[31b"
"\u001b[0`" represents an intra-field positioning sequence.
  • "\u001b[" = <CSI>
  • "0" = an ASCII numeric string representing the cursor offset position
  • "` = <HPA>
" \u001b[31b" represents a character repetition.
  • " " = the character to be repeated (a white space)
  • "001b[" = <CSI>
  • "31" = an ASCII numeric string representing the number of times to repeat the character
  • "b" = <REP>
You need to apply these partial field updates to the previously retrieved data of those fields.
Thank you @jirapongse.phuriphanvichai for your response
