sometimes same json that was valid changing the token of course,
i'm keep getting the error
Could not send request - Error: socket hang up
using via fiddler composer or via visual studio everything works fine.
thanks,
Yaniv
thanks,
Yaniv
From the problem description, the Postman didn't work but other applications worked fine. In this case, it could not be an outage issue.
You can register to get alert notifications via MyRefinitv.
Does this problem happen in Postman?
If yes, it may relate to settings in Postman.
Please share the request that you are using so I can test it on my Postman.
Hi Jirapongse,
Yes, its postman(as the tag shows).
Apparently entering to postman and running the query without changes worked perfectly.
Can it be that it would be related to web site Maintenance?
the reference header are:
Authontication: Token _*(given token for 24 hours)
Prefer : respond-async
Content-Type : application/json; odata=minimalmetadata
Host: selectapi.datascope.refinitiv.com
Content-length : 2496
the body content:
"ExtractionRequest": {
"@odata.type": "#DataScope.Select.Api.Extractions.ExtractionRequests.CompositeExtractionRequest","ContentFieldNames": [
"User Defined Identifier",
"RIC",
"Issue PermID",
"Ticker",
"Exchange Country Code",
"Security Description",
"CUSIP",
"ISIN",
"SEDOL",
"OCC Code",
"Currency Code",
"High Price",
"Low Price",
"Ask Price",
"Bid Price",
"Universal Close Price",
"Universal Close Price Date",
"Volume",
"Average Volume - 3 Months",
"Market Capitalization - Local",
"TRBC Industry Group Code Description",
"Asset Type",
"Asset Category Description",
"Asset SubType",
"User Defined Identifier2",
"Trading Status",
"Listing Status",
"Suspend Flag",
"Asset Status",
"Volatility - 30 days",
"Industry Description",
"User Defined Identifier4",
"Mid Dirty Price",
"Net Asset Value",
"Expiration Date",
"Maturity Date",
"Factor",
"Display Factor",
"User Defined Identifier3",
"Lot Size",
"S&P Rating",
"Contributor Code",
"Index Linked Bond Index Ratio",
"Accrued Interest",
"Market Capitalization",
"Instrument ID"
"IdentifierList": {
"@odata.type": "#DataScope.Select.Api.Extractions.ExtractionRequests.InstrumentIdentifierList","InstrumentIdentifiers": [
"Identifier": "TMV.DEU",
"IdentifierType": "Ric",
"UserDefinedIdentifier": "111",
"Source": ""
"Identifier": "MEDV.BR�",
"UserDefinedIdentifier": "222",
"Source": ""
"Identifier": "APHTQ",
"UserDefinedIdentifier": "333",
"Source": ""
"Identifier": "DWAS.O",
"UserDefinedIdentifier": "444",
"Source": ""
"Identifier": "HMDR.PK�",
"UserDefinedIdentifier": "555",
"Source": ""
"Identifier": "NDXX11750J",
"UserDefinedIdentifier": "666",
"Source": ""
"ValidationOptions": {
"AllowHistoricalInstruments": true,
"AllowInactiveInstruments": true,
"AllowLimitedTermInstruments": false,
"AllowOpenAccessInstruments": true,
"AllowSubclassImport": false,
"AllowUnsupportedInstruments": true,
"ExcludeFinrAsPricingSourceForBonds": false,
"UseConsolidatedQuoteSourceForCanada": false,
"UseConsolidatedQuoteSourceForUsa": true,
"UseDebtOverEquity": true,
"UseExchangeCodeInsteadOfLipper": false,
"UseOtcPqSource": false,
"UseUsQuoteInsteadOfCanadian": false
"UseUserPreferencesForValidationOptions": false
"Condition": null
