Elektron SDK - Java - 1.0.5 EMA VIEW example not working.
I can't seem to get the VIEW mode example to work in the latest Elektron SDK - Java - 1.0.5 EMA. All fields in the image and any updated field in the update, even though only bid (22) and ask (25) are requested.
specifically the com.thomsonreuters.ema.examples.training.consumer.series300.example360__MarketPrice__View example.
I have an RFA application that works OK against my ADS (which has a SNAP_AND_DYMAMIC_VIEW license, so I don't believe it's the environment.
9.5k 10 5 7
Hello clive.stokes,
EMA Java does not fully support View as mentioned in Elektron-SDK1.0.5.java\Ema\README at section 6. ISSUES AND WORKAROUNDS shown below:
Hence, the application still receives all fields.
Ok thanks, my bad. However I would question why there is an example in the release for a feature that does not work?
9.5k 10 5 7
Hello @clive.stokes
Elektorn SDK Java 1.0.7 which fully support dynamic view has been released. You can download it at https://developers.refinitiv.com/en/api-catalog/refinitiv-real-time-opnsrc/rt-sdk-java/download
If you cannot download the package, please contact RDC admin(rdc.administrator@thomsonreuters.com).
The fix is mentioned in Elektron-SDK1.0.7.java\Ema\README at section 7. RELEASE HISTORY shown below
I have run example360__MarketPrice__View with Elektorn SDK Java 1.0.7. The application worked proper. Only Bid and Ask field were returned as requested:
