COMPLEXORDER - Invalid Exchange Error on REDI API
I'm trying to send the diagonal options order below via the API but get Invalid Exchange error. NOTE:-
1. I have successfully entered the exact same order via the UI including destination and account.
2. I can successfully enter a single options order via API using the same account and exchange.
Please advise solution - thank you!
    Dim hOrder As New COMPLEXORDER
    ' Complex options order header
    hOrder.Strategy = "Diagonal"
    hOrder.SetSymbol 0, "VICI"
    hOrder.SetExchange 0, "DEM2 DMA"
    hOrder.SetPriceType 0, "Limit"
    hOrder.SetTIF 0, "Day"
    hOrder.SetQuantity 0, 1
    hOrder.SetAccount 0, "3FORGEDD"
    ' Long Put
    hOrder.SetSide 1, "Buy"
    hOrder.SetPosition 1, "Open"
    hOrder.SetOptType 1, "Put"
    hOrder.SetMonth 1, "Jan '23"
    hOrder.SetStrike 1, "30.00"
    hOrder.SetAccount 1, "3FORGEDD"
    ' Short Put
    hOrder.AddOptionLeg
    hOrder.SetSide 2, "Sell"
    hOrder.SetPosition 2, "Open"
    hOrder.SetOptType 2, "Put"
    hOrder.SetMonth 2, "Dec '21"
    hOrder.SetStrike 2, "25.00"
    hOrder.SetAccount 2, "3FORGEDD"
    hOrder.SetPrice 0, 4
    Dim errStr As Variant
    Dim rtnVal As Variant
    ' Send order object to REDI EMS
    rtnVal = hOrder.Submit(errStr)
redi-apiorder-entry
Hi @DDALY ,
Can you please try setting the exchange later? (see below example)
-Brian
Sub SendDiagonal2()
  Dim myerr As Variant
  hOrder.SetSymbol 0, "AAPL"
  hOrder.SetPriceType 0, "Market"
  hOrder.SetAccount 0, "DEMO2"
  ' Leg 1 of vertical spread
  hOrder.SetOptType 1, "Call"
  hOrder.SetMonth 1, "Dec '21"
  hOrder.SetStrike 1, "195.00"
  ' Leg 2 of vertical spread
  hOrder.AddOptionLeg
  hOrder.SetOptType 2, "Call"
  hOrder.SetMonth 2, "Nov '21"
  hOrder.SetStrike 2, "200.00"
  rtnVal = hOrder.Submit(myerr)
  If Not rtnVal Then
    If myerr <> "" Then
      MsgBox myerr
    Else
      MsgBox "Failed - Please Contact REDI Support."
    End If
  Else
    MsgBox "Submitted"
  End If
End Sub
@brian.mullane, That worked perfectly! Thanks a lot, Dermot
@brian.mullane, Just doing some more testing on above and I've noticed when I increase the quantity it still lands in REDI as 1 lot.. very strange. Can you check if you get the same result? Thanks, Dermot
23k 22 9 14
Hello @DDALY ,
Appears to apply for me:
 hOrder.SetQuantity 0, 5
Results in
Try to restart and retest, where you can be sure if it was the same order?
@zoya.farberov, I moved the SetQuantity to just before the Submit and now working fine. Thank You.
