How to send Stop Market entry order from Excel VBA to REDI Plus
Hello, I am trying to send a Stop Market entry order from excel VBA to REDI Plus, the code is like below,
Dim hOrder As New Order
hOrder.Symbol ='SQQQ
hOrder.Side = "Buy"
hOrder.Quantity = 100
hOrder.Exchange = "GSDE Algo"
hOrder.PriceType = "SOR GSDE"
hOrder.StopPrice = 26.88
hOrder.TIF = TIF
hOrder.Account = AccountID
hOrder.Ticket = "Bypass"
It filled as a market order immediately without waiting for he price breakout the StopPrice. I checked the variable, hOrder.IsStopPriceEnabled which is false in this case. My question is that how can I enable it?
Also I tried some other PriceTypes from the API, like the "Stop", it will pop up "PriceType invalid" error.
By the way, I am able to send the stop market entry order in REDI plus without problem. it just need to set the DESINATION as GSCO NA Eq Algo, the PRICE TYPE as SOR, the ORDER TYPE as Stop, and fill out the price in the "STOP" field instead of "PRICE" field. But in the API, there is only one property to set the "Price Type" and "Order Type", the options are:
• Market
• Limit
• Stop
• Stop Limit
• Peg Ask
• Peg Bid
• Peg Mid
• Market Close
• Limit Close
So how can I set them from VBA code to match the fields in REDI Plus?
redi-apiequitiesorder-entry
23k 22 9 14
Hello @Gerry Z,
If you are running a REDI Order Entry example (?), try:
1. Modifying generic order creation code to set StopPrice similar to:
hOrder.Side = Side
     hOrder.Quantity = Quantity
     hOrder.Symbol = Symbol
     hOrder.Exchange = Exchange
     hOrder.PriceType = PriceType
     hOrder.Price = Price
     hOrder.StopPrice = Price
     hOrder.TIF = TIF
     hOrder.Warning = False
2.Selecting Stop from the Order Type drop-down:
3. Verifying via RediPLus if the order submitted is, in fact, a stop order next:
Hope this helps
Zoya,
Thank you for the quick response, that's exactly what I am looking for. But unfortunately the examples I downloaded from github
https://github.com/TR-API-Samples/Example.REDI.VB.ExcelExamples
does not include the one you showed here, could you let me know where to find it or share it with me if possible?
Best,
Gerry
23k 22 9 14
Hello @Gerry Z,
I tested with Order Entry - PT Batch Load (Global Equities & Futures) example on
GitHub: /Example.REDI.VB.ExcelExamples.
