How can I check if a track is Total Return?
Given an instrument, I would like to know if the track associated is total return.
@bruno.rodriguez
Please kindly explain more about the question, such as the report template and instruments that you are using. Moreover, it will be helpful if you can share the request that you are using.
However, if the question is about the content, please contact the DSS support team directly via MyRefinitiv for a prompt response.
