EMA: hasPermissionData() on item for refresh/update message
Inside OnRefreshMsge() and OnUpdateMsg() I check if item has permission data by calling
message.hasPermissionData().
For the same item hasPermissionData() gives me TRUE if i'm inside a Refresh Message and FALSE if i'm inside an Update Message.
Is it normal? I'm struggling to understand why?
Thank you
elektronrefinitiv-realtimeelektron-sdkrrtema-api
Hi @DimAngelNX
As far as I am aware you only see Permission Data in a RefreshMsg - as the data applies to a particular Permissionable Entity and the permission data rarely changes for the instrument - so it makes no sense (from a permission-checking or bandwidth-usage point of view) to keep repeating the same bit of data.
Assuming that you are doing some sort of proxy permissions checks - you would check the permissions when a user first makes a request for an instrument - if they are permssioned, they can then be provided with the Refresh values and any subsequent updates.
If for some reason the permission data does change, you would receive another (unsolicited) Refresh for the same instrument with the revised permission data.
