i want to use the development station to interact with the refnitiv service the issue is that our development stations are in closed envirment, that means that i can only create the json request and using it via the postman for a check.
is there away to use some mechanism to debug the proccess of the httprequest/response via some structed the mechanism or application that i can use inside the closed envirment and that can immitate the request trasmittion and will reply with a response.
swagger for example is an option or there is something else i can use
