We have a connection using WebSockets. The normal connection method starts with a username password connection then every interval (x) a token authentication to see that we are still authorized. Over the past couple of weeks the service keeps getting interrupted where we have a failure to get the token authentication. Our process tries again and fails then a restart occurs and starts with the username password connection. This continues to fail also. After some time passes the program is started back up with a username and password authentication and it works again.
Any idea as to what is going on? It last starting occurring last night 8/10/2021 around 17:33 EDT. It failed a couple of times then made a successful connection again. Then at a certain point it simply stops for a long period of time and not accept the connection again.
The message received is:
"EDP-GW authentication HTTP code: 400 Bad Request"
