Hi
As soon as I connect to the websocket API I send a Login message with the access token which I got from the auth server. This works, I get a Login Refresh response and I can then subscribe to market updates.
This token expires at 5 minutes, at which case I imagine I need to refresh it, otherwise I get a token expired message.
Using the same process (and the same refresh token I had earlier) I get a new access token and send the same Authentication message. I do this 30 seconds before the expiry time of the first access token. The server responds nothing and later drops the connection.
