How to contribute the € Sign to a Text Fid or a Page Row?
How should I create the fieldList for Elektron API? (RSSL 14002)
I use below code nut it fail to send the "€" and I see strange Char instead.
is UTF8 the correct way?
FieldList fieldList = EmaFactory.createFieldList();
fieldList.add(
EmaFactory.createFieldEntry().utf8(Integer.parseInt(Row), "Hello € !"));
or
EmaFactory.createFieldEntry().utf8(1352, "Hello € !" );
EmaFactory.createFieldEntry().utf8(318, "Hello € !" );
elektronrefinitiv-realtimeelektron-sdkrrt
@michael.theimer
According to the data dictionary (RDMFieldDictionary), those fields are RMTES_STRING.
ROW80_4    "IRGROW 4"             318  NULL        ALPHANUMERIC       80  RMTES_STRING    80
DSPLY_NMLL "LCL LANG DSP NM"     1352  NULL        ALPHANUMERIC       32  RMTES_STRING    32
To send UTF8 characters in RMTES, you need the special escape characters, as mentioned in this discussion. Therefore, the code looks like this:
        ByteBuffer bbuf = ByteBuffer.allocate(14);
        byte[] partial = {
                  27,//0x1B
                  37,//0x25
                  48, //0x30 (0)
                  72,//H
                  101,//e
                  108, //l
                  108, //l
                  111, //o
                  32, //<space>
                  (byte) 226,(byte)130,(byte) 172, //0xE2 0x82 0xAC (€)
                  32, //<space>
                  33 //!
        bbuf.put(partial);
        bbuf.rewind();
        nestedFieldList.add(EmaFactory.createFieldEntry().rmtes(3, bbuf));
After posting this message, the Eikon Quote application showed the following.
