Receive RICs of all quotes given one ISIN of a company
Hi everyone,
if I enter a RIC of a companys primary issue in the search bar and if I select "All" in "Show Quotes for", then I see all the quotes that are available for that company (i.e. ordinary shares, preferred shares, depository receipts).
If I try to get the same list of all these quotes using the eikon API , I then I do get the same without the depository receipts. I use the following command:
data = ek.get_symbology(["DE0007100000"], from_symbol_type="ISIN", to_symbol_type="RIC", best_match=False)
Do you have any suggestions haw I can add the depository receipts?
Thanks in advance!
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonsymbology
6.7k 8 6 7
@Eikon10 You could also try our our excellent Search API:
rdp.search("DE0007100000",top=1000)
This should be very comprehensive. You can also use the Search API for more complex searches. There is an excellent article on the RDP Search API here. I hope this can help.
Hi @jason.ramchandani ,
thank you so much, that API is ideed excellent. It works great!
