C# stopped working
Hi All,
We have a job running that has stopped working. Our discovery services calls returns a content length of -1.
       public static bool DiscoverServices(string url = null)
            if (string.IsNullOrEmpty(url))
                url = _discoveryUrl;
            string param_url = url + "?transport=websocket";
            //Console.WriteLine("Sending service discovery request to {0}\n", param_url);
            HttpWebRequest webRequest = (HttpWebRequest)WebRequest.Create(param_url);
            webRequest.Headers.Add("Authorization", "Bearer " + _authToken);
            webRequest.AllowAutoRedirect = false;
            webRequest.UserAgent = "CSharpMarketPriceEdpGwServiceDiscoveryExample";
            try
                HttpWebResponse webResponse = (HttpWebResponse)webRequest.GetResponse();
                if (webResponse.ContentLength > 0)
We get a fine token however webResponse.ContentLength has started returning -1. Any pointers what could cause this?
websocketsrrtorefinitiv-realtime-optimised
Notice the default sample provided buy refinitiv does not work either. Same credentials works with python sample.
@thomas02
It looks similar to the question in this thread.
@thomas02
The code on GitHub has been updated.
Hi @thomas02
If you are using deriving your code from the GitHub example, please note that as well as the above chunking fix - there was another minor fix (a wrongly placed return true / missing return false statements). So,please ensure these are also applied to any code that is derived from the GitHub example.
