Unable to extract closing price for RIC Code - CRFRMc1 - Steaming Coal
I am unable to fetch closing price for CRFRMc1 (Steaming Coal) - It is throwing an error that data is not available for the requested date range
start date - 2020-01-01
end date - 2021-07-26
Have the RIC codes within Steaming coal changed recently?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonrics
@subarini
API8 CFR South China Coal Futures have been delisted from ICE Futures Europe effective 26 July 2021. For more details see https://www.theice.com/publicdocs/circulars/21108.pdf or Refinitiv alert 243116 (on Eikon see page ALERT8 in a Quote app).
I expect that Refinitiv will soon be removing RIC CRFRMc1 and other RICs related to the delisted futures from the real-time network.
1.4k 6 2 2
Hi @subarini ,
Looking through the Data Item Browser, I found that the item named 'TR.SETTLEMENTPRICE' would return values. Does the Python code below return satisfactory data?
df5, err = ek.get_data(instruments='CRFRMc1',
                       fields=["TR.SETTLEMENTPRICE.date",
                               "TR.SETTLEMENTPRICE"],
                       parameters = {'SDate': '2020-01-01',
                                     'EDate': '2021-07-26'})
df5.dropna()
@jonathan.legrand We are using the below mentioned method to extract the CLOSING prices for CRFRMc1 RIC Code & facing the above mentioned issue. We are able to extract closing prices of many other commodities with the same method, however, Steaming Coal is throwing this error.
P.S - This code has been functional for over 2 years and only started malfunctioning today.
ek.get_timeseries(list(ric_code_fixed.apply(str)),fields = ['CLOSE'], interval='daily', start_date=curr_start_date, end_date=curr_end_date, calendar="tradingdays")
Hi @subarini ,
Would you mind letting me know what the result of this get_timeseries use to be in the past? I have the impression that the field name was changed to 'TR.SETTLEMENTPRICE' or it was always the same as CLOSE and we decided to remove the latter to avoid confusion...
