Sofr RIC field value
Dear,
I am trying to collect some SOFR RIC (eg. SONIAOSR=) field values through RFA, and I want to know,
1) if the fields are correct PRIMACT_1 (value) and VALUE_DT1, VALUE_TS1 (fixing date and time)
2) for the RIC /SARON.S, there are no such fields return
*For previous RIC with tenor (eg. HIHKD1YD=), I used to collect the data in fields BID, VALUE_DT1, VALUE_TS1.
Thanks for advice.
trep
9.7k 49 38 60
Hi @ChunBongLee
Thanks for the clarification. If you generally want to understand the data model used by the different RICs, you can use the value defined within FID 5357 (CONTEXT_ID). You can use the value of this FID within the Data Model Discovery site. For example:
The document returned gives a complete breakdown of the FIDs and what they contain.
Hi @ChunBongLee
There should be no reason, unless you have found an issue, that the above fields are incorrect. If you believe there is an issue with the content, I would suggest you open a ticket within Refinitiv Support and they can assign a data specialist to investigate.
I was able to retrieve the above data, i.e.
You didn't provide any other details so I can only assume you are not permissioned to access this content. If this is the case, you can reach out to your Refinitiv Account Manager to discuss.
Hi @nick.zincone
Thanks for reply.
Sorry my previous question may be misleading. I just want to know the correct fields to get the data (and not saying the field value is incorrect)
So for SONIAOSR= or EUROSTR=
I am getting values successfully from: PRIMACT_1, VALUE_DT1, VALUE_TS1
But for /SARON.S, I find there are no values returned from PRIMACT_1, VALUE_DT1, VALUE_TS1
So I try to get the values from: TRDPRC_1, TRADE_DATE
And want to know if these fields are correct. Thanks.
