Hi all
I just wanted some advice around the new xsd path that should be included in the request XML that is sent to Refinitiv.
This is the URL that we have updated in the XML that we generate
"http://www.refinitiv.com/Datascope/ReportRequest.xsd"
Could you please let us know if you see any issues with this ?
We are also in the process of updating the SFTP connection URL to select.datascope.refinitiv.com.
So, I wanted to check in case there is any significance of what sequence these 2 changes are done ?
Since both old and new URLs are active in parallel from Refinitiv, I think ideally it would not make a difference in which sequence the above changes are carried out ?
Please let me know in case any further details are required.
Thanks in advance
Best Regards
Sid
