Problems with DSS FTP connection with Client WinSCP or automated script.
I have been attempting to get our automated script to connect to our site hosted.datascope.reuters.com.
When I test the connection with the client, CoreFTP, I AM successful using
Server: hosted.datascope.reuters.com/reports/
Port: 22
User: r9025260
Pass: xxxxxx (obscured) and no private key
I am NOT successful if I use the Client WinSCP
OR my automated script.
What I get back as a return value from your server is as follows:
“<?xml version="1.0"?><FTPResults xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><Success>false</Success><Msg>Connection has been unexpectedly closed. Server sent command exit status 0.
Authentication log (see session log for details):
Using username "r9025260".
Access denied.
Authentication failed.</Msg><FileInfo><string xsi:nil="true" /></FileInfo></FTPResults>"
Can you please have someone look at the log for this user and see if it reveals why one way works and the other doesn’t? Each method should be presenting the same public key.
dss-rest-apidatascope-selectdssFTPsftp
Hi @Lukasz Ossowski,
I have tried with latest WinSCP and have been able to connect both FTP and SFTP.
Like OpenSSL, WinSCP uses its own certificate store and prompted me to accept the new certificate - the first time I connected.
I would recommend that you update to the latest version and clear your old cached certificates.
Also, you can refer to this DSS ftp user guide.
Here is the same thing with CURL. You will need to manually import the RSA certificate into the OpenSSL trusted certificates list to avoid using the -k (insecure) switch.
>>>curl -k "sftp://hosted.datascope.reuters.com" --user "r999999:password"
drwxr-s---    6 109011672 30000           6 Mar 23  2017 .
drwxr-s---    6 109011672 30000           6 Mar 23  2017 ..
drwxrws---    2 101      30000          58 Sep 15 10:20 reports
drwxr-s---    3 101      30000           3 Sep 17  2018 feeds
drwx------    2 109011672 30000           2 Mar 23  2017 .ssh
drwxrws---    3 101      30000           3 Mar 23  2017 incoming
