From the error message, it looks like to be a problem with the proxy server which requires authentication.
You may need to contact your local IT support team to verify the problem. If you are using DSS .NET SDK, please refer to the answer in this thread.
Hi - Thanks for the reply - It doesnt appear that there is an issue with the proxy from our end. We think this as we're not seeing any blocks for authentication on the proxy server....
The code we're running works when we're connecting the previous URL we was using https://hosted.datascopeapi.reuters.com/RestApi/v1/%27 but are having issues with the URL we are attempting to use https://selectapi.datascope.refinitiv.com/RestApi/v1%27
The link to thread you've included - Apologies but i'm not aware if we're using DSS .NET SDK - What would be the best way to ascertain if we are?
Thank you
DSS .NET SDK contains the following DLLs:
ThomsonReuters.Dss.RestApi.Client.dll ThomsonReuters.Dss.Core.RestApi.Common.dll Or, DataScope.Select.RestApi.Client.dll DataScope.Select.Core.RestApi.Common.dll
The namespaces are:
using ThomsonReuters.Dss.Api.Extractions; using ThomsonReuters.Dss.Api.Extractions.SubjectLists; using ThomsonReuters.Dss.Api.Content; using ThomsonReuters.Dss.Api.Extractions.ReportTemplates; using ThomsonReuters.Dss.Api.Extractions.Schedules; using ThomsonReuters.Dss.Api; Or, using DataScope.Select.Api.Extractions; using DataScope.Select.Api.Extractions.SubjectLists; using DataScope.Select.Api.Content; using DataScope.Select.Api.Extractions.ReportTemplates; using DataScope.Select.Api.Extractions.Schedules; using DataScope.Select.Api;
If the application uses those DLLs and uses the above namespaces in the source code, it indicates that the application uses the DSS .NET SDK.
Thanks for the information above:
I have been reading on the hyperlinked previous issue you kindly provided - It spoke about using a new DSS .NET SDK version, where it looked like new code was downloaded and proxy details were added? Would this be what you advise? The link to download the latest DSS .NET can now can't be found so guessing its an old link....could you point me to the latest?
Thanks, Darren
Are you using DSS .NET SDK? The latest version (15.0) is available at https://developers.refinitiv.com/en/api-catalog/datascope-select/datascope-select-rest-api/download.
The answer on that thread shows how to use an authenticated proxy in DSS .NET SDK and C#.
If you are using other libraries or programming languages, you need to refer to the documentation of those libraries or programming languages regarding using or setting an authenticated proxy in those libraries.
From the question, the error message should be from the proxy server.
