Cannot connect to Refinitiv cloud using refinitiv sdk in my own app
I was able to run successfully the example provided in the Refinitiv sdk (113_MP_SessionMgmt) but when I try to use the same code in my own application it doesn't work.
Note that my server dlls/exe are in a "bin" folder but the server is run in the parent directory (in other words the current directory is not the bin directory). As it looks like some dlls are loaded dynamically could it he cause of the error I get:
loggerMsg
TimeStamp: 11:30:23.528
Severity: Success
Text: Received ChannelUp event on channel Channel_4
Instance Name Consumer_4_1
Connected component version: ads3.4.2.L1.linux.tis.rrg 64-bit
loggerMsgEnd
loggerMsg
TimeStamp: 11:30:23.529
Severity: Verbose
Text: Received ChannelReady event on channel Channel_4
loggerMsgEnd
loggerMsg
TimeStamp: 11:30:23.902
Severity: Warning
Text: Received ChannelDownReconnecting event on channel Channel_4
RsslReactor 0x0000000020A57050
RsslChannel 0x0000000020A57050
Error Id -1
Internal sysError 10035
Error Location D:\Jenkins\workspace\ESDKCore_RCDEV\OS\VS141-64\rcdev\source\rtsdk\Cpp-C\Eta\Impl\Reactor\rsslReactor.c:4884
Error Text <D:\Jenkins\workspace\ESDKCore_RCDEV\OS\VS141-64\rcdev\source\rtsdk\Cpp-C\Eta\Impl\Transport\rsslSocketTransportImpl.c:696> Error:1002 ipcRead() failure. System errno: (10035)
loggerMsgEnd
elektronrefinitiv-realtimeelektron-sdkrrtema-api
23k 22 9 14
Hello @Nicolas.Belhoste1 ,
In addition to the check suggested by @jirapongse.phuriphanvichai ,
As some ideas to troubleshoot, would it make sense to:
1. Go to bare bones as much as possible. Start with the working example, and little-by-little modify it to what you would like to have in your custom app per your requirements. See at what point the failure occures
2. See if you run your app as the same user/have the same permissions
3. See if all files and folders on the file system that your custom app may require are fully accessible by the user it is run as, read, write and execute permissions, just in case.
@Nicolas.Belhoste1
What is the version of EMA you are using?
If it is old, please upgrade it to the latest version. The latest version is Real-Time-SDK-2.0.2.L1.
I'm using RTSDK-2.0.1.L2.win.rrg, I can try the latest version, but the thing is that when I test a sample provided in the SDK, it's working. When I put the same code in my own app it doesn't work.
