For the elektron websocket api what is the maximum number of RICs that you can be subscribed to?
elektron
9.7k 49 38 60
Hi @vikas.khurana,
Perhaps I misunderstood your question. The answer above is related to the size of a batch you can safely send to the server. The actual number of open requests depends on the limitations of your license. You will need to confirm with your account manager what your license is entitled to in terms of the maximum watchlist size.
9.7k 49 38 60
So there isn't a limitation on the number of RICs? We only just need to break the batch message apart? 10k RICs, 100K rics all can work?
