**See below comment** RTO is returning strange character encodings.
If I request something like dIBMd, I'm expecting to get encoded data from ts1 via Elektron.
Does anyone know how what I get back in the FIDs ROW64_1 (through 14) is encoded? I have an is this in UCS-2, UTF-16, UTF-8, etc?
I already understand how to decode ts1 data once it is in its binary form, but I need to get this into it first.
RECEIVED on dIBMd: { "PROD_PERM": 3063, "RDNDISPLAY": 0, "BOND_TYPE": " ", "ROW64_1": " !????M$9\\+v???? <??????TC>????<??!??????7j m]??<J??1Th$????a6|(|????z(??C???? ??????\"??2g", "ROW64_2": "??Jz,$?? 0!????p#????(Vn9???????:??D)???^??^p?? 9z2 &??)n????j????n??E??2??)?? ", "ROW64_3": " ", "ROW64_4": " ", "ROW64_5": " ", "ROW64_6": " ", "ROW64_7": " ", "ROW64_8": " ", "ROW64_9": " ", "ROW64_10": " M\"\"??+?? 6?:aj |??.,?? N]??", "ROW64_11": "??L PZ_u_uv +??_w?????F??}~9??@??$??,?????.??n??[????L??6??d???????????{!?? ????Ur9'????7??", "ROW64_12": "d????!??|3??6sP??5v???? ??I>%y_u??#q????v??_tQ3?????nA~!^;._tY????Ec??z??[????Z!K$?????????????", "ROW64_13": ")9??F>??3????{??H??ow??????6V]S???????????T????%Wi<??????+??7????g???_uv??~????_p????????_t????????LN|??", "ROW64_14": "?????yJ]??????????Bp????\"x??????E????????????%\"zVr??\"??Mx??l???????????1??????????)xD????i}B\"??&??|??????", "RECORDTYPE": 237, "REG_ID1": 0, "REG_FIELD1": "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=", "ROW1_TIME": null, "ROW2_TIME": null, "ROW3_TIME": null, "ROW4_TIME": null, "ROW5_TIME": null, "ROW6_TIME": null, "ROW7_TIME": null, "ROW8_TIME": null, "ROW9_TIME": null, "ROW10_TIME": null, "ROW11_TIME": null, "ROW12_TIME": null, "ROW13_TIME": null, "ROW14_TIME": null, "BYTE_BMAP": 0, "PREF_DISP": 0, "DSO_ID": 0 }
I get the above using:
var readBuffer = new ArraySegment<byte>(new byte[Constants.BUFFER_SIZE]); MemoryStream memoryStream = null; byte[] dataBuffer; while (true) { try { var result = await WebSocket.ReceiveAsync(readBuffer, Cts.Token); if (!result.EndOfMessage) { if (memoryStream == null) memoryStream = new MemoryStream(Constants.BUFFER_SIZE * 5); memoryStream.Write(readBuffer.Array, readBuffer.Offset, readBuffer.Count); readBuffer = new ArraySegment<byte>(new byte[Constants.BUFFER_SIZE]); } else { if (memoryStream != null) { memoryStream.Write(readBuffer.Array, readBuffer.Offset, readBuffer.Count); dataBuffer = memoryStream.GetBuffer(); memoryStream.Dispose(); } else { dataBuffer = readBuffer.Array; } break; } } catch { cSpec.CloseSessions(this, null); } } JArray messages = JArray.Parse(Encoding.ASCII.GetString(dataBuffer));
