Null result on GDP API R Timeseries request
Hi all!
I'm trying to pull some GDP time series data (RIC: aIDCGDPPD/A) in R using the eikonapir package. However, my request is returning null values (see below). I have a feeling this is because something in my request is incorrect, but I can't figure out what. Can
The 'ECONOMIC.Timestamp' and 'ECONOMIC.Value' fields are taken from my search in the Excel formula builder. Can anyone tell me whats wrong?
> GDPqq <- eikonapir::get_timeseries("aIDCGDPPD/A",
                                   start_date='2020-01-02T15:04:05-07:00',  # start date
                                   end_date='2022-06-06T15:04:05-07:00', # end date
                                   fields=list('ECONOMIC.Timestamp', 'ECONOMIC.Value'),
                                   interval = "quarterly",
                                   debug = T)
[1] "Request *************************************"
{"Entity":{"E":["TimeSeries"],"W":{"rics":[["aIDCGDPPD/A"]],"fields":[["ECONOMIC.Timestamp"],["ECONOMIC.Value"]],"interval":["quarterly"],"startdate":["2020-01-02T15:04:05-07:00"],"enddate":["2022-06-06T15:04:05-07:00"]}}}
[1] "Response *************************************"
[1] "{\"timeseriesData\":[{\"dataPoints\":[[null,null],[null,null],[null,null],[null,null],[null,null]],\"fields\":[{\"name\":\"ECONOMIC.Timestamp\",\"type\":\"\\u003cnil\\u003e\"},{\"name\":\"ECONOMIC.Value\",\"type\":\"\\u003cnil\\u003e\"}],\"ric\":\"aIDCGDPPD/A\",\"statusCode\":\"Normal\"}]}"
[1] "Response status *************************************"
[1] 200
eikonworkspaceworkspace-data-apirefinitiv-dataplatform-eikonapieikon-data-api-r
@economics01
The get_timeseries method can be used to only retrieve "default" historical view data.
Typically, it returns the OPEN, HIGH, LOW, CLOSE fields.
Please share the formula created by the Excel formula builder to retrieve the 'ECONOMIC.Timestamp' and 'ECONOMIC.Value' fields.
@economics01
The code should look like this:
GDPqq <- get_timeseries("aIDCGDPPD/A",
           fields=list('*'),
           interval = "quarterly")
GDPqq
The output is:
18k 21 12 20
Hi @economics01
You can add interval = 'quarterly' parameter in your request and remove the field name (to get all available fields)
