Proxy Authentication Error
Refinitiv Websocket API. The error we are getting is "proxy authentication required". I have attached a picture of the error.
websocketsrrtorefinitiv-realtime-optimised
11.5k 16 7 10
Hello @Abdifatah
Based on the given error message, it seems the machine cannot connect to the RDP API Gateway.
Are you running the application in your corporate network/Firewall?
Please test the following CURL command in the same machine:
curl --location --request POST 'https://api.refinitiv.com/auth/oauth2/v1/token' \
--header 'Content-Type: application/x-www-form-urlencoded' \
--header 'Authorization: Bearer ' \
--data-urlencode 'username=<Username/Machine ID>' \
--data-urlencode 'password=<Password>' \
--data-urlencode 'grant_type=password' \
--data-urlencode 'scope=trapi' \
--data-urlencode 'takeExclusiveSignOnControl=true' \
--data-urlencode 'client_id=<App Key>'
