Hi team,
We are having some issues to establish connection through EMA API, the client has a proxy so i used the next parameter to create the Cosumer configuration
tunnellingProxyHostName
tunnellingProxyPort
but the next error is showing
I've not been able to replicate the error from my side and i have not clue what could be the problem
the Keystore parameters are optional i've tried with and withouth keystore parameters (including the .jks file) and it works from my side but the client has this issue
does EmaConfig.xml file need aditional configuration for proxy? or Java has any option to work with proxies related with EMA API?
Any ideas on how to solve this?
Thanks for your support!
