Docker LPC PULL Error
We are preparing to switch over from EZD. I have just installed Docker on Windows environment and trying to pull lpcdocker/lpc as required in the documentation.
It throws the following error message:
docker pull lpcdocker/lpc
Using default tag: latest Error response from daemon: manifest for lpcdocker/lpc:latest not found: manifest unknown: manifest unknown.
Not sure what to do next or if any switches missing. Can you please advise?
elektronrefinitiv-realtimeelektron-sdkrrt
Docker images do not have the "latest" tag applied. The LPC 1.2 instructions specify to use the version when using Docker Pull:
docker pull lpcdocker/lpc:1.2.0.L1
Hi Christopher
Thank you for your response. worked as specified.
Have a good day.
Nader
